Hello Steve, earlier I asked about the option to use Bome translating the 14bit NRPN from my Andromeda A6 to midi cc to use it 's knobs as midi controllers for audio units in Logic.
I have captured the NRPN messages of incrementing Andromeda Oscilator 1 from 0 to full.
would this project be enough for you to guide me in programming all the 80 plus knobs of the andromeda to midi cc?
I changed your translator for NRPN 0 as you requested. For converting any 14 bit value to 7 bits, you will lose precision, so I am basically only using the MSB (Most significant byte) value of the incoming NRPN. I use the LSB (Least significant byte) of the NRPN Number to determine the CC # to use. See translator 0.0.
Now to go a step further, I disabled the above translator and created a new on (0.1) that will take any incoming NRPN and use the NRPN LSB to convert to the CC number and the NRPN MSB value to sent the value to the CC.
So NRPN 0 with MSB value 5 becomes CC0 value 5. MSB value of 5 is actually 5<<7 ( 5 shifted 7 bits left ) which would be a value of 640.
If you put the search string ‘Log’ to filter the log window you will see how I am using the values.
Here is an example as I twist a few knobs with ‘Log’ in the filter search string.
1521764 - 0.1:5 Log Incoming NRPN 0 value is 10693 decimal
1521764 - 0.1:6 Log MSB for CC0 Value is 0x53 or 83 decimal
1522273 - 0.1:5 Log Incoming NRPN 0 value is 10692 decimal
1522273 - 0.1:6 Log MSB for CC0 Value is 0x53 or 83 decimal
1522652 - 0.1:5 Log Incoming NRPN 0 value is 10691 decimal
1522652 - 0.1:6 Log MSB for CC0 Value is 0x53 or 83 decimal
1522652 - 0.1:5 Log Incoming NRPN 0 value is 10690 decimal
1522652 - 0.1:5 Log Incoming NRPN 0 value is 10689 decimal
1522652 - 0.1:5 Log Incoming NRPN 0 value is 10688 decimal
1522652 - 0.1:5 Log Incoming NRPN 0 value is 10687 decimal
1522652 - 0.1:5 Log Incoming NRPN 0 value is 10686 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10685 decimal
1522653 - 0.1:6 Log MSB for CC0 Value is 0x53 or 83 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10684 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10683 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10682 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10681 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10701 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10761 decimal
1522653 - 0.1:6 Log MSB for CC0 Value is 0x54 or 84 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10805 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10872 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10918 decimal
1522653 - 0.1:6 Log MSB for CC0 Value is 0x55 or 85 decimal
1522653 - 0.1:5 Log Incoming NRPN 0 value is 10974 decimal
1522654 - 0.1:5 Log Incoming NRPN 0 value is 11001 decimal
1522654 - 0.1:6 Log MSB for CC0 Value is 0x55 or 85 decimal
1522762 - 0.1:5 Log Incoming NRPN 0 value is 11031 decimal
1522762 - 0.1:6 Log MSB for CC0 Value is 0x56 or 86 decimal
1522762 - 0.1:5 Log Incoming NRPN 0 value is 11032 decimal
1522762 - 0.1:5 Log Incoming NRPN 0 value is 11033 decimal
1522762 - 0.1:5 Log Incoming NRPN 0 value is 11034 decimal
1523289 - 0.1:5 Log Incoming NRPN 0 value is 11035 decimal
1523289 - 0.1:6 Log MSB for CC0 Value is 0x56 or 86 decimal
1523289 - 0.1:5 Log Incoming NRPN 0 value is 11036 decimal
1523289 - 0.1:5 Log Incoming NRPN 0 value is 11041 decimal
1523289 - 0.1:5 Log Incoming NRPN 0 value is 11042 decimal
1523289 - 0.1:5 Log Incoming NRPN 0 value is 11049 decimal
1523289 - 0.1:5 Log Incoming NRPN 0 value is 11050 decimal
1523290 - 0.1:5 Log Incoming NRPN 0 value is 11059 decimal
1523290 - 0.1:6 Log MSB for CC0 Value is 0x56 or 86 decimal
1523290 - 0.1:5 Log Incoming NRPN 0 value is 11060 decimal
1523290 - 0.1:5 Log Incoming NRPN 0 value is 11066 decimal
1523290 - 0.1:5 Log Incoming NRPN 0 value is 11067 decimal
1523290 - 0.1:5 Log Incoming NRPN 0 value is 11068 decimal
1525806 - 0.1:5 Log Incoming NRPN 1 value is 5110 decimal
1525806 - 0.1:6 Log MSB for CC1 Value is 0x27 or 39 decimal
1526323 - 0.1:5 Log Incoming NRPN 1 value is 5109 decimal
1526323 - 0.1:6 Log MSB for CC1 Value is 0x27 or 39 decimal
1526323 - 0.1:5 Log Incoming NRPN 1 value is 5108 decimal
1526323 - 0.1:5 Log Incoming NRPN 1 value is 5107 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5106 decimal
1526324 - 0.1:6 Log MSB for CC1 Value is 0x27 or 39 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5105 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5104 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5103 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5102 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5101 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5100 decimal
1526324 - 0.1:5 Log Incoming NRPN 1 value is 5099 decimal
1526759 - 0.1:5 Log Incoming NRPN 1 value is 5100 decimal
1526759 - 0.1:6 Log MSB for CC1 Value is 0x27 or 39 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5101 decimal
1527250 - 0.1:6 Log MSB for CC1 Value is 0x27 or 39 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5102 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5103 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5104 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5105 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5106 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5107 decimal
1527250 - 0.1:5 Log Incoming NRPN 1 value is 5108 decimal
If you need different NRPN’s to map to CC0-80 then there will be further rules needed to do the conversion. In general, it is easier to use raw MIDI and rules so that you can use a single MIDI translator to do mapping for multiple possibilities rather than one translator for each NRPN you want to map.
I also used an alias for your device name. That way if a physical port name changes, you can simply re-assign the aliases. This is usually useful if you have multiple translators and don’t want to go through and update them all. Here are how I set up my aliases. Note, I do not have your device so I just created an alias ‘My Andromeda’ and linked it to my controller.
Hello steve sorry to bother you with a follow up question…
I somehow only get midi in from my Andromeda in Bome but Bome is not logging any output to the virtual out. Selected the physical midi input of the Andromeda on my midi interface as midi in in Bome. Then as midi output i selected bome virtual out 1 and also the alias you created.
In Logic prefrences I selected bome virtual out as input in Logic.
I deselected the straight midi signal from the Andromeda in Logic’s preferences.
If you see MIDI IN message but not incoming messages it means that the translator does not match what your Andromeda is sending. Perhaps it is sending only 7 bit NRPN messages. Please copy and paste what you see from the log file and then that will help me determine if I need to make adjustments to the translator.
