Hello!
I just want to ask how the process goes to use
the OP-Z synth (connected via USB on BomeBox)
as a clock, and sync with another synth via DIN out.
How should I set that up in Bome Network?
Thank you!
It should be pretty easy. By default all ports on the BomeBox are routed to all other ports (except their own). Just hook up your OP-Z to the USB port and you MIDI DIN OUT to you Synth.
If you don’t have all ports routed to all other ports, you can set up a routing on the routing page from OP-Z to MIDI DIN and you should all set. Just don’t forget to hit save. Also, it is important to have the OP-Z sending on the same MIDI Channel as your synth. You need to check your OP-Z and synth settings to do this.
Thank you so much, Mr. Caldwell!
Mr. Bomers, BomeBox, and your expertise and care
are wonderful and admirable.
This is truly a great community
and I am proud to be a part of.
I will share any knowledge I attain
during my BomeBox voyages.
