Hi, if you have something that can communicate the mouse current position to MIDI Translator (serial or otherwise) then MIDI translator will be able to send out relative changes in position but it only will do this for the primary monitor. Bome MIDI translator has no concept of a secondary monitor.
I actually have written a program called MIDIBuddy that can communicate to MT Pro the position of the mouse via MIDI Sysex if you manually move your mouse. MT Pro can then use this so it is aware of the current position and send relative movements afterwards. However it will only do this on the primary monitor. For information about MIDIBuddy, go to http://sniz.biz
