Greetings,
I have set up Bome as the interface between my controllers and LoopB pipes, and between the virtual pipes and my system. So far so good.
I have also set up aftertouch to activate CC 3. I have a question. How do I go about selecting some or all channels to convert aftertouch to CC 3? Incoming allows the selection of all channels. Outgoing only allows a single channel from the dropdown menu or there's a box underneath. I can type a channel in, but I have no idea how to type in multiple channels. I tried commas, hyphens, etc. I have attached a screenshot of the outgoing channel selection options.
I've cloned the first translator and am converting aftertouch on the two most important channels, but that's just a workaround.
I was also thinking about setting up a rule, but again, how do you type in multiple channels and attach that to a variable? What I want is to have aftertouch from the controller (DMC-122), converted to CC 3 on all virtual ports and all channels. Here's the details so far:
Incoming:
-dropdowns are set to MIDI Message and Channel Pressure
-port is the physical DMC-122 controller
-channel is set to any channel
-pressure is set to any pressure
-set variable to pressure is checked and qq is selected from dropdown
Outgoing:
-dropdowns are set to MIDI Message and Control Change
-for channel there is no option for any, so created 2 translators and set one to ch 2 and the other to ch 3
-would like to know how select multiple channels outgoing. I'm sure it's simple. I just can't get it
-CC # is set to 3
-value is set to qq (I assume that's a built in variable?)
-outgoing ports are virtual 1 to 16 (all of those ports are fed by the DMC-122)
Would like to get by with one translator if possible. Otherwise I will have to create 14 more translators to get aftertouch converted to CC 3 on all ports.
You've been great so far, and I really do appreciate your help. By the way, I did look through the manual, but there were only 5 references to channel and none of those helped me out.
Graham
