Outgoing Key Strokes Issue
I just set up a pad on my launch pad to execute Alt(Ctrl(I)) this is ‘Invert Selection’ in Cubase.
However for some reason the Physical Keys just ain’t working. However if I make separate translators for Alt, Ctrl and (I) and use Down and Up it works just fine. If someone could confirm this it sure would be grouse.
Key Stroke Issue.bmtp (2.5 KB)
As of MT Pro version 1.9.0 you can not slow down outgoing keystrokes for this type of situation and the good news is you do not have to create multiple translators.
Here is the outgoing action section within a single translator that you will need. The option is called “Emulate keystrokes slowly”.
