Outgoing keystrokes not working
I am trying to set up a quick way to edit hexadecimal data in the field on the right using a keystroke to first, double click the mouse and then either Backspace or Ctrl(V). The mouse clicks are working but neither of the keystroke outgoing actions seem to be working at this point. I have a delay of 500ms on the outgoing. Any Ideas why?.
Keystroke Issue.bmtp (1.4 KB)
My guess is that the issue is your original keystroke will not be suppressed by Bome MIDI Translator Pro. It will recognize incoming keystrokes but not suppress them Best to stick with incoming MIDI messages and not keystrokes.
So the project I posted didn’t work your end either?.
I didn’t even try it because I know that incoming keystrokes would interfere with mouse actions. If you want to do it with incoming MIDI, I can show you how.
