Everything works perfectly and is connected, but the PAIR light on my second BomeBox is not lit.
I wonder why…?
If you press the pair button does it flash? Does it flash at power up? What version of Firmware are you using?
When I press the PAIR button, it doesn’t flash, and the power-up also doesn’t flash the PAIR light.
The firmware version is: v1.5.4.
But I noticed that the PAIR indicator is lit very, very faintly - perhaps there is an issue with the LED light…? Because all connections are working fine.
It appears so, if you would like a replacement please reach out to us on our contact page for making arrangements.
Thank You!
I sent my application through the website.
