Paraplegic drummer looking to connect MRT audio breath controller to a Bomebox then my Roland TD17kvx 2 to generate kick drum sound
Hello all, I’m having trouble getting figuring out how to get the proper translators and parameters loaded into the box. I’ve used AI to help generate some code and it looks simple enough but I’m struggling.
Thanks in advance for any help….peace…Craig
What is the MIDI signal that your controller sends do you want to use that the Roland will use to generate the sound?
If you have started a Bome MIDI Translator Pro project file, could you post it. Of course you need to paid version of Bome MIDI Translator Pro to create the project if you want to run it on a BomeBox.
