Pass all midi CC in a preset but block CC30
Hello, I am trying to pass all midi CC as they arrive with this preset, the only thing is that I want to block CC30, because I am converting CC30 into program change with swallow ON in another preset
The issue is that my software receive both program change messages with the other translator as well as the CC30 even tho I created a preset with ‘none’ on the output.
The only way to block CC30 is to uncheck my ‘Other CCs’ translator
Well, I’d have to see the rules of your translators to be sure but one way to fix it would be to move translator 2 up to position 0 and then put stop processing as an option for that translator.
Translators are processed top to bottom until they reach the end or until you use stop processing in a translator that is triggered.
See the flowchart on page 100 of the Bome MIDI Translator Pro manual.
