I’m totally newbies with midi prog. I actually try to control kontakt library CC#1 or CC#11 with platform nano fader. I work on studio one. Nano work on mackie control protocol. I’v tried to prog it with btm but without succès. Can you give me some help please? Thanks in advance
For input we use what Mackie Fader 1 would send. We discard the least significant byte (LSB) and only use the most significant byte (MSB) for output. We thin use the MSB (qq) as the value of CC1
Faders 2-8 will start with E1-E7 and master fader will start with E8.
Set the alias “My Controller” to your Platform Nano. I suggest you set the alias “Application” to Bome MIDI Translator 1 Virtual Port. On your system it may show to other application as “BMT 1”.
Thanks for awnser, I’v tried this but it’s still not working. It correctly send a message to “log windows” but not in my kontakt library. To be sure, in my daw (studio one), what’s output and input? Btm virtual out or nano platform?
Well the translator should work but I’m not familiar enough with Studio One to know how to route your MIDI to a specific plugin instrument. I only have Studio on Prime and I don’t think this version allows for external (non-Presonus) plugins. At least I couldn’t find the right menu to add them.
