I was just wondering whether using a PoE injector with a ground pin on the power plug is necessary/recommended? Or does it not matter?
Also, are some recommended over others? 48V seems like a no brainer of course. High amperage too for USB devices. Should i also be seeking one with a metal chassis to reduce noise? I may end up mounting this under a pedal board so i was thinking that may be a concern.
