PoE Power Option for BomeBox
I am looking to use PoE to power my BomeBox on a guitar pedalboard. The only power source I have to power the BomeBox is an MXR M242 power supply. I have a 9v 500ma output (2.1mm center negative barrel connector) on this power supply and would like to know if this PoE injector would be suitable: https://mm.digikey.com/Volume0/opasdata/d220001/medias/docus/1889/435_Web.pdf
Thanks for any advice regarding this.
Hi, I wouldn’t recommended it due to the footnote on the description (not true to POE spec). I suggest instead to use a USB power adapter of sorts to step down the power to 5 V from 9 V. 500ma is OK but certainly may not handle more tha 2 attached USB devices if you are using the BomeBox host port.
Can the BomeBox accept 9v at its micro USB port without damage?
No USB should be 5 volts:
Here is an experpt from the specifications:
  • Power: requires 0.75W, either
    • via Micro-USB Type B: 5V (150mA) with a standard cell phone charger, or
    • via Power over Ethernet (PoE, 48V): PoE In port
