Preset Conundrum
What I would like is this:
If Preset 1 is deactivated,
Preset 2 is activated,
But only if Preset 3 is active,
So I imagine it is done with rules, but I have no idea how to do this. I have a workaround but thought there must be a quicker way.
Hi @Jesse.B
1 - Outgoing action on Preset 1 on deactivate to timer “Deactivate Preset 2”
2 - Outgoing action on Preset 3 to activate preset 2 with incoming trigger timer of Activate Preset 2. It will only be triggered if preset 3 is active. If preset 3 is not active, the timer will never be triggered.
See the attached. No rules required.
Preset-Conundrum.bmtp (1.0 KB)
Many many thanks. Really helpful. :smiley:
