Pretty new to the midi translator game here. I’m trying to get a simple dj controller (numark dj2go2 touch) to work on a software music player that our company designed. So it’s basically all done with outgoing mouse clicks and keystrokes.
What i can’t figure out is how to translate a 2 action input from the controller. Like a knob that’s pressed and turned or a jog wheel that’s is touched on the top and then turned. These are all 2 separate incoming midi messages that I want to output to 1 keystroke.
I guess i need to do this with rules but I tried with online videos and no luck. Maybe you guys can guide me in the right direction?
The first translator sets the global variable ‘ga’ to 1 when a note is pushed. I’m assuming the push action produces a note on. It has no output. See rules
The second translator resetst the global variable ‘ga’ to 0 when the button is released. I’m assuming on release your controller sends a note-off.
The third translator take a CC value on input and only sends a keystroke ‘a’ if the value of ga=1 (pushed). If it is not pushed (ga=0) it does nothing. Again see rules. Note that this is the only translator with an outgoing action.
My aliases are set up as shown here. You will need to re-assign those to fit your configuration.
You may also need to change the incoming triggers to match your encoder.
Device selection in my project is at the project level.
