Hi!
I have problems getting my BomeBox to work as a DHCP master and in APIPA mode. What I would like is only one ethernet connection between Bomebox and a laptop with ethernet-adapter, and it seems it should work. My laptop is MacbookPro M1 with Monterey 12.4. The only way I can get it to work with ethernet is with bomebox as client if I also connect it through a switch that also has a connected router with DHCP-server.
In the “network settings” of my mac I immediately get an IP from DHCP when I connect to my router, but when I connect (only) to the Bomebox this never happens (it only makes self assigned IP and can’t find the BomeBox). Wondering if I have missed something. The wifi is also turned off both on the laptop and the Bomebox when I try this.
