In the version above were different bugs, but g0 ist set to 1 under the label \"click\", because I needed the first impuls for a click too.
I’ll send the version which works for me now, but I’d like to solve it in the other version too…
This is, what i wanted to do:
g0=g0+1
if g0==1 then Goto “A”
if g0==24 then Goto “A”
if g0==48 then Goto “A”
if g0==72 then Goto “A”
if g0==192 then Goto “B”
exit rules, skip Outgoing Action
Hi, I’m trying to pause a tick for Tap Tempo derived from Midi Clock every 4 beats, but I do something wrong in scripting: clicker counter timing if g01 then Goto 1st … Many problems encountered when using PCs to record music are caused by MIDI or audio data not being delivered on time, or by its flow being interrupted.
I’m not sure exactly what you are trying to do but every 1/4 note would be 24 clicks so if you have 4/4 timing and you don’t want to pause it would be 4*24 or 96 ticks. if you want to drop a single click tick you should suppress output of the tick for every count of 96. If you want to pause a full quarter note beat for every measure then you should suppress clock ticks every 72 ticks for 24 ticks.
