I'm planning to integrate a Roland MC-707 into my studio and have successfully been able to translate start/stop/clock/SPP messages as well as note on/off.
But, would it be possible to translate an array of note on/off messages on yet another channel to control clip changes on all eight synth tracks?
Currently, I am using a set of eight note numbers on channel 9 ('Scene Change') to send Program Change messages on channel 16 to change between the eight scenes in the unit.
Could I do something similar with 105 notes on yet another set of channels ('Clip Change') and map all 105 to sending a Program Change for anywhere between 0-15 for that channel going to the MC-707?
What I'd want to do is map 15 note numbers per octave to send a 0-15 Program Change to their specific channel.
Would I need to specify each set of 15 manually in the 'Clip Change' rules?
Thanks for your help and insights in advance!
1588229926723_MC-707-Control-1.1.txt
