I'm a drummer and I have some Ableton Live experience, but I'm not particularly tech savvy. I also have no experience using your software.
I'm trying to incorporate my MIDI pad into my Ableton performance and I've run into a problem.
I set up the drum pad using a Drum Rack. I prepared a bunch of effects and I want a different one to effect the sound each time the pad is being played. The drum pad is sending MIDI notes to Ableton.
I set up an effect rack so that I can use the chain selector to select different effects. The problem is, that I want the chain selector to move itself randomly so that the chain selector doesn't have to be controlled manually.
Now Steven was amazing and sent me a file that does what I want it to do, but unfortunately I'm having a couple of issues which I hope can be resolved.
1. Often (about 33% of the time) the initial sound goes through more than one chain. I'd like it to go through one chain only.
2. Sounds are often repeated, sometimes as much as 3 times. Ideally I’d want no repeating.
1. I tried mapping to a different CC but the problem #1 still remains. Even if I only use one mapping in a test set this still happens.
Thank you and best regards
Kevin
1582678862527_Random-CC-Original.bmtp
