Rekordbox 7 DVS Pitch Bend Mode
Hello Bome Team & Community,
is it possible to make a Macro for my Idea Rekordbox Pitch Bend in DVS Relative Mode.
In Rekordbox you can only use Pitch Bend +/- in the Internal Mode, but not in Relative Mode to map this workly on the Buttons.
My Idea is, to make a Macro with 3 Variables.
Push the Button are temporary Pitch Bend +/- switch in Internal Mode, after Release the Button, to Switch back in Relative Mode automatically. Is this possible to Map??
The Easiest Way will be with Midi to Keytrokes, or will better work with Midi Notes from Rekordbox?
With best Regards
BB
Bome MIDI Translator Pro can certainly send MIDI to Rekordbox, but I’m not sure if Rekordbox has the capability to use that MIDI for changing modes. Alternatively Bome MIDI Translator Pro can convert MIDI to keystrokes. It really depends much on how Rekordbox handles those keystrokes.
If using keystrokes, I would suggest you test your theory manually by using your keyboard first. If it works, let me know what keystrokes are required to make it work manually an what MIDI messages you want to use to send these keystrokes and I should be able to help.
