hello
i want to map my Reverb & Delay buttons on my Omnis Duo screen in External mode with rekordbox7
How can i do it with bome please ?
I’m no expert on Rekord Box or the Omnis Controller. If I understand correctly the Omnis Duo controller is MIDI compatible and if you have a paid plan that supports MIDI functions, you should be able to map the MIDI controls to certain functions within RekordBox.
Looking at the RekordBox manual, however, didn’t show any mapping functions used for reverb or delay.
It is probably best to check with PioneerDJ to see if these functions can be MIDI mapped. Then if we know the MIDI messages that are needed by RekordBox it should be mappable. These are two big IFs.
You can download a trial copy of Bome MIDI Translator Pro here to test and see if it works before purchasing the paid version of Bome MIDI Translator Pro . The trial version is fully functional but times out every 20 minutes.
I did a bit more testing and was able to assign FX1 On/Toggle for Reverb and Level Depth and FX2 On/Toggle for delay. I have a generic MIDI controller and am using the trial version of RekordBox which supports MIDI in. You can use MIDI Learn in performance mode, so you should be able to map any unused controls on your Omnis Duo Controller to any MIDI messages that Rekordbox supports for MIDI learn.
This is the document of the MIDI that your Omnis Duo Controller sends.
thank you for your answer!
can you please tell me if i can remap my XP2 with rekordbox ?
i want to choose Reverb & Echo effects , any ideas how can i do it please ?
More than likely. It is a MIDI device. Use MIDI learn.
Set up your controller to use a Bome MIDI port and set MIDI paths as follows. Anything without a translator will pass through those paths.
Then use MIDI learn for the functions that you want. If you need to change the outgoing MIDI from your controller, you can write translators in Bome MIDI Translator Pro. You might need write translators for both the outgoing and return paths.
This posting is an example of what was done on an APC MINI MK2.
thank you, but i want to map something that i’m not find it in midi learn .
i just need to know the midi code from rekordbox , that will shows me correctly Reverb Midi adress & Echo Midi adress .
now after setting routings , i cant see anything happened when i choose fx from rekordbox in bome midi line …
You will need to see if that is mappable by reaching out to Rekordbox support. My guess is not everything on the UI is MIDI mappable.
