Repeat set of key strokes for X times
Hi, not sure if this is possilbe: for the keystroke action, is it possible to specify a set of keystrokes to be repeated X time, ideally mixing it with single keystrokes commands?
Example:
// Press backspace and down arrow in sequence for 20 times, then press right, right, esc
{backspace down}x20 right right esc
In a nutshell this would require multiple translators and a few global variables. One used as a key stroke counter (for a timer) and another used for a sequence/step counter to count where you are within a given sequence. My question would be would it always be the same number of certain keystrokes? If not what incoming MIDI command would you expect to tell Bome MIDI Translator PRO how many of each keystroke that you want to send?
Ok I asked just to be sure there wasn’t a special syntax for this. I will just repeat the commands 20 times I guess
Or you can use a repeating timer and set the repeat count to 20, each outputting the key once.
