Hi
is it possible to use Euphonix MIDI Euphonix port 2 as MIDI IN for BMT pro…?
How to set the MIDI Router …?
My understanding is the Euphonix is the original company that developed the proprietary EUCON network protocol. It was purchased by Avid, and I’m not aware of any MIDI development on that protocol. You did not mention whether this port is part of any type of controller or application that you are using. My guess is you may be running Pro-Tools or Cubase as I believe Steinberg (Cubase) actually has some EUCON support for some of their controllers.
Thank
It is in Davinci Resolve and it tends to be by default so I had hoped for a workaround by Bome ;o)
Davinci Resolve might use EUCON for Fairlight only, but it also uses Mackie and you can use Mackie MCU to control faders in Davinci Resolve. I think that is the only MIDI Davinci Resolve understands natively so for everything else you need to convert to keyboard shortcuts or mouse actions.
