A while ago Florian (and you) made me a custom preset with a sweep that increased the intensity of a laser. I am having a hard time creating the opposite whereby the sweep decreases the intensity. I’d appreciate any nudges you could give me. FYI- I have Intensity set to CC #74.
How (can) I make a new timer? I wanted both an “Up” intensity and a “down” intensity sweep. However I think I need a new timer for the down sweep. I’d appreciate any help!
I have the global variable gd, controlling the delay between iterations. It is currently set in the rules of translator 0.0. If you want a different delay, you can set a new variable for the other delay and then use that instead of gd in the Down timer (translator 1.2)
Ok thank you. I’m a bit puzzled as to which exact values I can even try for that newly created variable. Any thoughts on what to put in? I appreciate you!
