Win 11 Behringer X Touch with Ableton 12 Track and Remote enabled in Ableton on both In and Out, Same enabled in Project In and Out in BMT. “Swallow” box checked. The bottom midi sent indicator in Live Not Flashing plus in Bome it shows Router Out instead of Keystroke Out. I think I may have a virtual Midi Port enabled somewhere but I am baffled at the moment. Any help would be awesome. Trying to understand and not be scared of BMT ![]()
Do you have a project file? What are you trying to accomplish with the translator? Do you want to use your X-touch as a control surface or as a MIDI track input.
In general, router out means that MIDI is going out of Bome MIDI Translator pro via the MIDI router and not via translator. If you are looking for keystroke out, you would need to have a translator with an incoming MIDI signal to control an outgoing keystroke, but I can’t tell what you are trying to do without a further explanation and a project file.
Thanks so much Will work on this shortly!! thanks again
