Hello, I have a problem with a file, when i open it, there is a lot of rules corrupt options. Help !
Hi, and welcome to the Bome community!
Could you please post the offending project file?
Yeah MIDI BOME DAWRF 9.9.1.bmtp (1.4 MB)
Yes, I’m getting errors too. Do you have a previous version of the project file that worked? Maybe there is some sort of issue in saving the project file. What version of Bome MIDI Translator are you currently using?
Thanks, my translator version is 1.9.0.
The last version with no bug is
Yeah MIDI BOME DAWRF 9.5.bmtp (1.3 MB)
This is this code that make trouble :
ic=0
if id==0 then ya=0
if ya==0 then id=1
ya=ya^1
xa=0
xb=0
xc=0
xd=0
xe=0
xf=0
xg=0
xh=0
xi=0
xj=0
xk=0
xl=0
xm=0
xn=0
xo=0
xp=0
xq=0
xr=0
qq=1
if va==1 then qq=0
The problem is inside this code :
xa=0
xb=0
xc=0
xd=0
xe=0
xf=0
xg=0
xh=0
xi=0
xj=0
xk=0
xl=0
xm=0
xn=0
xo=0
xp=0
xq=0
xr=0
I have rewrite all the code of the preset that make problems, and replace all de variable “x” by a “j”, and it work fine ! 3 hours of work, but it work
Sorry for having to re-write! Please make sure your build is 1022. I think the earlier build had the problem with variables starting with x,
I’m sorry to hear of this trouble!
I can confirm that this is a bug that appeared in version 1.9 build 1018 and was fixed in 1.9 build 1022.
See here:
Be aware that this bug still exists in BomeBox firmware version 1.5.
