hi steve, wish you a happy new year. you repostet me somewhere, that with new update there is a way to save state of the values of global variables when the project gets closed. does this happen? best greetings tiberio
Not in MT Pro itself. I created a helper App for Windows only that allows you to save them in a file, however, it is a serial process so you would need to be patient while it saves them. PM or email me if you are interested in purchasing it. I think I called it MIDI Helper or (mh). There are a handful of people out there using it.
