hi!
i’m wondering, i miss that possibility to name the variables. like timer1 or trigger_inst5.
would that be possible? hard to keep track on the double letter variables.
cheers, henrik
hi!
cheers, henrik
I’m afraid not. You can name timers but not variables. Variables are restricted to 2 letter abbreviations as discussed in the user manual.
ah ok, thats sad. when using 50 or more I would probably loose them in the code.
maybe a little variables-library windows would help, where all variables are listed in a table and you could write comments next to it.
greetings, henrik
Yes, here is what I do.
Hey Steve,
ok I see, thanks!! yes in fact i do remember doing that back in school
days
cheers
I have a text file that contains all meanings of variables
Also made a tool to dump the unused variables list
See also:
Cross reference all variables, timers, etc: https://www.bome.com/support/kb/cross-reference-list-of-all-variables-in-a-mt-pro-project
Array emulation via compilation: https://www.bome.com/support/kb/array-emulation-using-4-sequential-variables-and-automatic-generation-of-rules
