I’m using an Akai APC mini to control Pangolin Quickshow queue’s and want to use it as a flash trigger so i don’t have to repress to deactivate the queue.
From my trial and error, using a keystroke emulation does not work if i want to trigger the flash mechanic and i need to use the key down and key up function for each button for it to work. however I need to be able to use both the big Q and small q distinguishable because I trigger each queue with a keyboard letter, both capital letter and not capitalized and i haven’t found a way to make a sequence that presses “Shift” right before the Q button presses since it has to be capital letter.
I have made a sequence with 2 translators that each trigger the shift down and the Q down on the midi that comes with pressing the midi-button down, and then Q up and shift up for the midi-button when its released with a small delay on the first Q down and the shift up.
How can i make this in just 2 translators with a key sequence instead of 4 translators with a delay?
