Setting Global Variable?
Is there a specific place where I should set Global Variables in a broader set of presets? I’m a little confused…thanks in advance!
I usually set up a single translator to set document them in rules. You can also set them there as well but it makes for a better reference when you go back years later.
See this tutorial.
