Hello! Tried to search the forum for this, as I’m sure it’s been covered, but the terms are quite generic and not sure if I’m using the correct terminology
We wish to use BOME MT Pro to do the following:
1.performing a live show with Ableton Live. One Live set contains all ~20 songs from our set arranged in scenes using the Session view. Each scene contains a unique set of Drum Racks, VSTs, Audio clips etc.
- have a BOME MT Pto Project with a number of Preset that correspond to each of songs in the set which translate incoming commands from 2 Korg MicroKontrols (and possibly one other Midi controller?) so that as we change scene/song in Ableton the keys, pads, faders etc on each MicroKontrol change their mapping/function in relation to the specific Instruments/Clips in each Ableton Scene. (For example Song 1 faders 1-8 on Mikrokontrol 1 are mapped to a pair of ADSR envelopes on a VST, but in Song 2 the same faders control the Oscillator mixer section of a different synth etc)
3.As each scene in Ableton is triggered a dummy clip in Ableton sends a message out to Bome MT Pro to proceed to the preset that corresponds to the Ableton Scene.
Assuming all three are possible - how does one set up midi mappings to select Presets in BOME MT Pro?
Thanks for any help and sorry if this very obvious!
