I just download the demo of Bome Midi Translator Pro.
I would like while using Dorico software to control Logic Pro X in the background with my ShuttleExpress like debreved
I’m not so familiar with midi.
I set my ShuttleExpress button to the keystroke F12
I can get Keystroke In response in the Event monitor but no midi out.
Hi and welcome to the Bome Forum! Since there is another post with this same question, I will delete the other (duplicate) post.
First of all, in your project file, you have not defined the MIDI output port you want to send to. Please go to the project level by first clicking on the file name to the left and the the desired project ports to the right. (see diagram)
Then, say that you have Bome MIDI Translator 1 Virtual port checked. In you application, you need to receive from the same port (if short names are set in your settings in may show as “BMT 1”)
Edit:
Oops, the diagram is showing MIDI input ports. You will need to scroll down and check the MIDI output ports instead.
Another note, Fn(F12) might not be the best choice as outgoing keystrokes are not suppressed and the operating system may be using it for something else.
I was doing another mistake.
In the incoming Key Stroke action box,
I was pressing the F12 button from my computer keyboard instead
of my ShuttleXpress F12 keystroke button.
Now as I set everything as you explained It’s work! ^.^
I can control Logic in the background using Dorico with the my ShuttleXpress!
