Hi there, I want to make it so that the bottom row of my Launchpad MK 2 are lighted up at all times, color doesn’t particularly matter. I am very new to this and I honestly don’t understand any of it. I saw the video with blinking lights but I couldn’t manage to make a static light out of it. Would be nice if someone could explain how to do it.
That is precisely what I was looking for, thank you very much. Am I correct in assuming that the 90 stands for the channel, the second hexadecimal for the note number and the third (qq) for the velocity/color?
As you can see things are very similar for the first few bits. After “10” things get interesting, so 0A is just setting a constant color, 23 makes it flash and 28 pulsate. the $LL and $CC are just placeholders I use here, $LL means LED number. Which number is assigned to which pad depends on the mode the pad is in. It´s different from drum grid mode to programmer/custom mode for example. It may even differ across the various launchpad models, but so far it looks the same, at least for pro mk1 and mini mk3 (which I own).
Let´s say you are in user mode and want a constant light on your lower row in white, then sending this would do the trick:
Likewise, $CC is a place holder for the colour (77 = white). You will find a full color matrix in the novation programmer references. The mk3 references have color tables in decimal and hex.
