Strange behavior when typing in Raw MIDI / System Exclusive
I am finding it difficult to type in Raw MIDI / System Exclusive . I am trying to type “MIDI 90 00 7F” and it comes out all weird in the 3 different fields. And the Translator is different again. See pictures.
Inconsistentcy BMTP
Inconsistentcy BMTP 2
Cheers,
As you can see in the upper part, BT tries to interpret the word ‘MIDI’ as variable. Don’t write that word. Only numbers or variable names.
Hi @Jesse.B
If raw outgoing MIDI messages you can only enter raw hex numbers which includes the numbers 0-9 and letters A-F. Also add a single space between number pairs. You should not enter the word ‘MIDI’ here. If you want, however, you can enter it as a comment preceded by to slashes ‘/’. Then everything on that line will be treated as a comment and not processed.
//MIDI
90 00 7F
