Hello! Wondering if anyone out there has attempted to create a script for a TX-6 CC to HUI for Pro Tools. Just downloaded the BMTPro and cant seem to get them to communicate
What project file did you try? What CC’s do you want to send for each fader?
HUI is pretty picky and you will also need to have your project send a ping response after setting up ProTools for HUI.
This video shows how to set up ProTools but in this case we will not be using Mackie to HUI conversion. Instead we will do CC to HUI conversion.
In that attached example I use a MIDI Fighter Twister and have created translators for 2 fader using CC0 and CC1 on MIDI CH1.
The required HUI ping response is also included as translator 0.0
Here are how I have my aliases set up. You will need to modify for your controller and possibly for the CC number it sends as well.
HUI-2Faders-example-2023-05-26c.bmtp (5.0 KB)
Thanks Steve! I’ll play around with it tomorrow. The project file I tried was ‘1589766585024_CC10-Encoder-toHUI-Fader1-App.bmtp’. I haven’t put much time into this yet and the video and other .bmtp will probably help me get there… If I hit a dead end I might circle back around but very much appreciate you pointing me in the right direction
My guess is you didn’t properly define your alias virtual port for HUI App.
