PLEASE IGNORE THIS THREAD.
Translator 0 – Channel Message
Incoming – MIDI Note On, any channel, set velocity to "pp"
[x] swallow (...)
Outgoing – MIDI Note On, channel "gt", velocity "pp"
Translator 1 – Increment +
Incoming – MIDI Raw: "B0 22 7F"
Rules – if gt<15 then gt=gt+1
Outgoing – none
Translator 2 – Decrement –
Incoming – MIDI Raw: "B0 22 01"
Rules – if gt>0 then gt=gt-1
Outgoing – none
And formatted as pre-format:
Incoming – MIDI Note On, any channel, set velocity to “pp”
[x] swallow (…)
Outgoing – MIDI Note On, channel “gt”, velocity “pp”
Incoming – MIDI Raw: “B0 22 7F”
Outgoing – none
Incoming – MIDI Raw: “B0 22 01”
Outgoing – none
[x] swallow (…)
Outgoing – none
Outgoing – none
Incoming – MIDI Note On, any channel, set velocity to ”pp”
[x] swallow (…)
Outgoing – MIDI Note On, channel ”gt”, velocity ”pp”
Incoming – MIDI Raw: ”B0 22 7F”
Rules – if gt0 then gt=gt-1
Outgoing – none
[x] swallow (…)
Outgoing – none
Posting a question with MT Pro ”code” works, but indentation is removed and quotes are replaced to typographical quotes.
Putting the code into a ”Preformatted” block will add additional New Lines and the lower-than and greater-than symbols are replaced with HTML entities.
posting an answer works fine, except that quotes are replaced by typographical quotes. Might be OK if ”preformatted text” works OK…
posting a comment mangles the content (check out what has become of the Rules lines!) and removes stuff (”Translator 2” is missing entirely). Also, putting it in a PRE tag does not do anything (second comment).
Posting an answer using Preformatted text style:
[x] swallow (...)
Outgoing – none
Outgoing – none
same problems as in posting a question.
a comment with ”quotes”.
The backslashes for ”escaping” the quotes are visible directly after inserting the comment, but not after reloading the page.
another test. I’ve changed the backend setting “escape pre tag” to OFF now:
Incoming -- MIDI Note On, any channel, set velocity to "pp"
[x] swallow (...)
Outgoing -- MIDI Note On, channel "gt", velocity "pp"
Outgoing – none
Outgoing – none
huh! that seems to fix all issues!
Add Media button does not work. But attaching an image works, although it’s always displayed at its native resolution.
