I created a simple translator that will only pass through note values above a certain range, however it only works when I use tt as the note value. Any other variable causes it to fail sending the note off message. Here are two examples (see attachments).
The only difference is using qq instead of tt. I've tried several other variables, but tt is the only one that correctly passes the note off value.
Here are the differences in the output (though I don't really know how to read them):
Test1
1: MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 92 00 20
2: MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 92 00 20
3: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 92 00 20
4: MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 82 2B 40
5: MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 82 2B 40
6: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 82 2B 40
Test2
1: MIDI OUT [Bome MIDI Translator 3 Virtual Out]: 92 9E 23
2: MIDI OUT [Bome MIDI Translator 2 Virtual Out]: 92 9E 23
3: MIDI OUT [Bome MIDI Translator 1 Virtual Out]: 92 9E 23
Any help would be greatly appreciated!
1587544558767_Test1.bmtp
1587544558868_Test2.bmtp
