Timer mouse click
hi… how many repeat count dods allowed for one click two different mouse click in different position?
in other wotds how can i get three different position moude click with just on click? thanks
one trigger click i meant
You can have a repeating timer that clicks the mouse any number if times and set it up so it clicks at a different location for every iteration.
Typically you set a counter to see what iteration you are at and then use that to determine the next click location
Incoming: Note on MIDI CH 0 note 0 any value
Rules : gc=20
Outgoing: Click TImer 20 times initial delay 10 ms repeat delay 10 ms
Incoming : Click timer
pp=gc
gc=gc-1
// x position
if pp==20 then qq=10
if pp==19 then qq=20
// y position
if pp=20 then tt=20
if pp=19 then tt=10
Outgoing: Mouse click at x position y positin tt
wow… i can hav more than 2 different click position then?
i sll got something to do right noe steve,…but for sure I will try it later.
whats pp refers to?thaks
pp and tt are local variables you can use within the translator. to specify the storage for values you want to use. There are 10 local variables available per translator
oo pp qq rr ss tt uu vv ww xx
There are 360 global variables that can be shared between translators
ga-gz g0-g9 ha-hz h0-h9 … za-zz z0-z9
This is all called out in the user manual. (Help menu or F1 from within MT Pro)
works great…thanks mate
FYI…i try to use local var yy and zz…and ts work.thanks
Pardon my understanding…accodring to ur statement above so i can use same local var as long as they in different translator right?
There are only 10 local variables oo through xx. Every thing else is global.
Local variables can be re-used but they are common to any translator with the same incoming trigger so. This can sometimes be used to your advantage making some things “semi-private”. For the most part, however consider them private. I seldom run into name collisions due to this little understood fact.
i see… so i has to different translator and different trigger source right?
You are correct.
They are local to the incoming trigger.
