I have made a TOGGEL function that can set a NOTE and a KEY Stroke with the same midi in.
but after a number of other different midi in signals, the function only works after 2 strokes the same midi in
can you help…?
It is unclear to me based on what you posted if you want to send the keystroke on each press or only when toggle LED is on. This example will only send the keystroke when LED is on. I’m using a different outgoing keystroke than you so you may need to change that for your country.
Toggle-MIDI-And-Key-2021-12-13.bmtp (1.2 KB)
