I am using Bome for multi client gaming.
Ive been using two machines and a FCB-1010 midi pedal box for many controls.
This has allowed for sending separate commands for some things and universal buttons for things to happen in both clients.
This has worked ok as a Master/Slave situation which is nice but lacks control on the slave. However I want to try and run this on a single machine.
The main reason for trying one machine is the ability to have a button to switch screens between the two clients for a smooth takeover on the other client and full control. The problem seems to be routing certain translators to one window vice versa, while keeping the universals going to both.
Also a desire to have a main control and a secondary control scheme that toggles based on which client has mouse focus I.E.
Each client has its own window name thats basically CharacterName - ServerName
First how do I direct the universal cmds to both clients regardless of which has mouse focus?
I see application focus as an output option but dont understand how to utilize in this context.
Second how can I create a toggle that uses either mouseLocation/Click or windowName to make the switch from CliA to CliB while swapping the functions of the secondary buttons to CliA and back to CliB when I switch back?
something like
tog = 0 on togPress +1 | if tog = 1 then tog=0
To create a toggle variable. Then
if tog=1 click on and route to CliB
else click on and route to CliA
Any help would be fantastic.
This utility is amazing and I have gotten so many different uses from it from gaming, music production, to daily computing.
