Hi, I’m hoping someone can help? I would like to control Davinci Resolve’s edit pages using messages sent from “Touchosc”. The problem at the moment is that both apps are on the same PC, so when press a button in touchosc it takes the focus away from davinci. I understand there is a feature in BMT to add to the outgoing message to keep focus, but I’m not having any joy with this. If anyone has any ideas, I would be grateful. Many thanks
I assume you are trying to control Davinci Resolves with mouse clicks, mouse movements, or shortcuts. Unfortunately, while your moving something in Touch OSC, you will not be able to focus on Davinci Resolve or vis-versa. Now if you are sending, and Resolve understands a MIDI command, you do not need focus so that may work but Davinci resolve’s MIDI control is pretty much limited to the mixer functions.
I think the solution would have to be moving your Touch OSC application to an iPad device or similar, or perhaps to a different computer. Another solution would be to purchase aa a low cost external MIDI controller.
Hi Steve, thanks for the welcome and response. I’ve resigned myself to the fact that this is going to be more trouble than it’s worth, and probably not possible anyway. I do have Touchosc on a tablet that I can use for this. In fact for many years I was using that method with video and various DAW’s. It was just that I have large touchscreen already integrated into my multiscreen setup and its been great for other apps to control, so it’s just a shame it wont work with Resolve.
Once again, thanks for your reply.
Regards
Chris
