When I plug in my pioneer controller and try to map it in voicemeeter potato, the knobs and sliders are not working properly. They receive signal, but they flash up and down, and dont increase or decrease smoothly. Is there anything that can be done for this? Thanks!
Yes, See my example attached. I created one translator. In my case my input devices is a DDJ-SB3 and the knob is sending a 14 bit control change on MIDI channel 2.
I used the capture feature of Bome MIDI Translator Pro and clicked on the correct entry.
I then modified the value to a local variable (qq) for manipulation in rules.
In the rules section I use a scaling method to modify from a range of 0-16383 (14 bit) to a range of 0-127 (7 bit). This is called ‘scaling’.
Here is a tutorial on scaling.
For the outgoing message, I set up a 7 bit CC with the same MIDI channel and CC number and use the new modified value of qq.
I select the input device as my DDJ-SB3 and use a Bome Virtual Port (Port 1) for output)
In Voicemeeter I set my input device to BMT 1 (which is the short name exposed for the same virtual port on my system.
I can now use MIDI learn for that knob. I used fader strip 1.
Attached is the project file I used.
DDJ-14to7-bit-example.bmtp (1.1 KB)
I opened the project, checked the Capture Midi checkbox on Incoming, and the midi message output I’m getting on the log are Raw MIDI / System Exclusive hexadecimal numbers.
I moved the slide from down to up, and this is the entire log I’m getting (same thing happens when I turn the knobs as well)
388012 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7F
388012 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388016 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7F
388016 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388019 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7E
388019 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388023 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7E
388023 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388026 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7D
388026 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388030 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7D
388030 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388032 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7C
388032 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388035 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7B
388035 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388039 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7B
388039 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388042 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7A
388042 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388045 - MIDI IN [DDJ-SB2 MIDI]: B0 00 7A
388046 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388049 - MIDI IN [DDJ-SB2 MIDI]: B0 00 79
388049 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388053 - MIDI IN [DDJ-SB2 MIDI]: B0 00 79
388053 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388056 - MIDI IN [DDJ-SB2 MIDI]: B0 00 78
388056 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388059 - MIDI IN [DDJ-SB2 MIDI]: B0 00 78
388059 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388062 - MIDI IN [DDJ-SB2 MIDI]: B0 00 77
388062 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388065 - MIDI IN [DDJ-SB2 MIDI]: B0 00 77
388065 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388068 - MIDI IN [DDJ-SB2 MIDI]: B0 00 76
388068 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388071 - MIDI IN [DDJ-SB2 MIDI]: B0 00 75
388071 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388074 - MIDI IN [DDJ-SB2 MIDI]: B0 00 75
388074 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388077 - MIDI IN [DDJ-SB2 MIDI]: B0 00 74
388077 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388080 - MIDI IN [DDJ-SB2 MIDI]: B0 00 74
388080 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388083 - MIDI IN [DDJ-SB2 MIDI]: B0 00 73
388083 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388086 - MIDI IN [DDJ-SB2 MIDI]: B0 00 73
388086 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388089 - MIDI IN [DDJ-SB2 MIDI]: B0 00 72
388089 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388092 - MIDI IN [DDJ-SB2 MIDI]: B0 00 72
388092 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388095 - MIDI IN [DDJ-SB2 MIDI]: B0 00 71
388095 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388098 - MIDI IN [DDJ-SB2 MIDI]: B0 00 70
388098 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388102 - MIDI IN [DDJ-SB2 MIDI]: B0 00 70
388102 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388106 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6F
388106 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388109 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6E
388109 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388113 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6E
388113 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388116 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6D
388117 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388120 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6C
388120 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388124 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6C
388124 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388127 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6B
388127 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388130 - MIDI IN [DDJ-SB2 MIDI]: B0 00 6A
388130 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388134 - MIDI IN [DDJ-SB2 MIDI]: B0 00 69
388134 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388137 - MIDI IN [DDJ-SB2 MIDI]: B0 00 69
388137 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388140 - MIDI IN [DDJ-SB2 MIDI]: B0 00 68
388140 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388144 - MIDI IN [DDJ-SB2 MIDI]: B0 00 67
388144 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388147 - MIDI IN [DDJ-SB2 MIDI]: B0 00 67
388147 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388151 - MIDI IN [DDJ-SB2 MIDI]: B0 00 66
388151 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388154 - MIDI IN [DDJ-SB2 MIDI]: B0 00 65
388154 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388158 - MIDI IN [DDJ-SB2 MIDI]: B0 00 64
388158 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388161 - MIDI IN [DDJ-SB2 MIDI]: B0 00 64
388161 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388164 - MIDI IN [DDJ-SB2 MIDI]: B0 00 63
388164 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388168 - MIDI IN [DDJ-SB2 MIDI]: B0 00 62
388168 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388171 - MIDI IN [DDJ-SB2 MIDI]: B0 00 61
388171 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388175 - MIDI IN [DDJ-SB2 MIDI]: B0 00 61
388175 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388178 - MIDI IN [DDJ-SB2 MIDI]: B0 00 60
388178 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388181 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5F
388181 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388184 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5F
388184 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388187 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5E
388187 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388190 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5D
388190 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388193 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5C
388193 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388196 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5C
388196 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388199 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5B
388199 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388202 - MIDI IN [DDJ-SB2 MIDI]: B0 00 5A
388202 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388205 - MIDI IN [DDJ-SB2 MIDI]: B0 00 59
388206 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388209 - MIDI IN [DDJ-SB2 MIDI]: B0 00 59
388209 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388212 - MIDI IN [DDJ-SB2 MIDI]: B0 00 58
388212 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388216 - MIDI IN [DDJ-SB2 MIDI]: B0 00 57
388216 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388219 - MIDI IN [DDJ-SB2 MIDI]: B0 00 56
388219 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388223 - MIDI IN [DDJ-SB2 MIDI]: B0 00 55
388223 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388226 - MIDI IN [DDJ-SB2 MIDI]: B0 00 54
388226 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388230 - MIDI IN [DDJ-SB2 MIDI]: B0 00 53
388230 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388233 - MIDI IN [DDJ-SB2 MIDI]: B0 00 52
388233 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388237 - MIDI IN [DDJ-SB2 MIDI]: B0 00 51
388237 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388240 - MIDI IN [DDJ-SB2 MIDI]: B0 00 51
388240 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388243 - MIDI IN [DDJ-SB2 MIDI]: B0 00 4F
388243 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388246 - MIDI IN [DDJ-SB2 MIDI]: B0 00 4E
388246 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388250 - MIDI IN [DDJ-SB2 MIDI]: B0 00 4E
388250 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388253 - MIDI IN [DDJ-SB2 MIDI]: B0 00 4D
388253 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388257 - MIDI IN [DDJ-SB2 MIDI]: B0 00 4C
388257 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388260 - MIDI IN [DDJ-SB2 MIDI]: B0 00 4B
388260 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388264 - MIDI IN [DDJ-SB2 MIDI]: B0 00 4A
388264 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388267 - MIDI IN [DDJ-SB2 MIDI]: B0 00 49
388267 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388271 - MIDI IN [DDJ-SB2 MIDI]: B0 00 48
388271 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388274 - MIDI IN [DDJ-SB2 MIDI]: B0 00 47
388274 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388278 - MIDI IN [DDJ-SB2 MIDI]: B0 00 46
388278 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388281 - MIDI IN [DDJ-SB2 MIDI]: B0 00 45
388281 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388284 - MIDI IN [DDJ-SB2 MIDI]: B0 00 44
388284 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388288 - MIDI IN [DDJ-SB2 MIDI]: B0 00 43
388288 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388291 - MIDI IN [DDJ-SB2 MIDI]: B0 00 42
388291 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388294 - MIDI IN [DDJ-SB2 MIDI]: B0 00 41
388294 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388297 - MIDI IN [DDJ-SB2 MIDI]: B0 00 40
388297 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388300 - MIDI IN [DDJ-SB2 MIDI]: B0 00 40
388300 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388349 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3F
388349 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388352 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3F
388352 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388356 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3E
388356 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388359 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3D
388359 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388363 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3C
388363 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388366 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3B
388366 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388370 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3A
388370 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388373 - MIDI IN [DDJ-SB2 MIDI]: B0 00 3A
388373 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388376 - MIDI IN [DDJ-SB2 MIDI]: B0 00 39
388376 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388380 - MIDI IN [DDJ-SB2 MIDI]: B0 00 38
388380 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388383 - MIDI IN [DDJ-SB2 MIDI]: B0 00 37
388383 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388386 - MIDI IN [DDJ-SB2 MIDI]: B0 00 37
388386 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388389 - MIDI IN [DDJ-SB2 MIDI]: B0 00 36
388389 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388393 - MIDI IN [DDJ-SB2 MIDI]: B0 00 35
388393 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388396 - MIDI IN [DDJ-SB2 MIDI]: B0 00 34
388396 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388399 - MIDI IN [DDJ-SB2 MIDI]: B0 00 34
388399 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388403 - MIDI IN [DDJ-SB2 MIDI]: B0 00 33
388403 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388406 - MIDI IN [DDJ-SB2 MIDI]: B0 00 32
388406 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388409 - MIDI IN [DDJ-SB2 MIDI]: B0 00 32
388409 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388412 - MIDI IN [DDJ-SB2 MIDI]: B0 00 31
388412 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388415 - MIDI IN [DDJ-SB2 MIDI]: B0 00 30
388415 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388418 - MIDI IN [DDJ-SB2 MIDI]: B0 00 30
388418 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388421 - MIDI IN [DDJ-SB2 MIDI]: B0 00 2F
388421 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388424 - MIDI IN [DDJ-SB2 MIDI]: B0 00 2E
388424 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388427 - MIDI IN [DDJ-SB2 MIDI]: B0 00 2D
388427 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388430 - MIDI IN [DDJ-SB2 MIDI]: B0 00 2D
388430 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388434 - MIDI IN [DDJ-SB2 MIDI]: B0 00 2C
388434 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388437 - MIDI IN [DDJ-SB2 MIDI]: B0 00 2B
388438 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388440 - MIDI IN [DDJ-SB2 MIDI]: B0 00 2A
388440 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388443 - MIDI IN [DDJ-SB2 MIDI]: B0 00 29
388443 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388447 - MIDI IN [DDJ-SB2 MIDI]: B0 00 28
388447 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388450 - MIDI IN [DDJ-SB2 MIDI]: B0 00 28
388450 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388454 - MIDI IN [DDJ-SB2 MIDI]: B0 00 27
388454 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388457 - MIDI IN [DDJ-SB2 MIDI]: B0 00 26
388457 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388461 - MIDI IN [DDJ-SB2 MIDI]: B0 00 25
388461 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388464 - MIDI IN [DDJ-SB2 MIDI]: B0 00 24
388464 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388467 - MIDI IN [DDJ-SB2 MIDI]: B0 00 24
388468 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388471 - MIDI IN [DDJ-SB2 MIDI]: B0 00 23
388471 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388475 - MIDI IN [DDJ-SB2 MIDI]: B0 00 22
388475 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388478 - MIDI IN [DDJ-SB2 MIDI]: B0 00 21
388478 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388482 - MIDI IN [DDJ-SB2 MIDI]: B0 00 20
388482 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388485 - MIDI IN [DDJ-SB2 MIDI]: B0 00 20
388485 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388488 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1F
388488 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388492 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1E
388492 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388495 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1D
388495 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388499 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1D
388499 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388503 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1C
388503 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388506 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1B
388506 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388509 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1B
388509 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388512 - MIDI IN [DDJ-SB2 MIDI]: B0 00 1A
388512 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388515 - MIDI IN [DDJ-SB2 MIDI]: B0 00 19
388515 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388518 - MIDI IN [DDJ-SB2 MIDI]: B0 00 19
388518 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388521 - MIDI IN [DDJ-SB2 MIDI]: B0 00 18
388521 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388524 - MIDI IN [DDJ-SB2 MIDI]: B0 00 17
388524 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388527 - MIDI IN [DDJ-SB2 MIDI]: B0 00 17
388527 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388530 - MIDI IN [DDJ-SB2 MIDI]: B0 00 16
388531 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388534 - MIDI IN [DDJ-SB2 MIDI]: B0 00 15
388534 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388537 - MIDI IN [DDJ-SB2 MIDI]: B0 00 14
388537 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388541 - MIDI IN [DDJ-SB2 MIDI]: B0 00 13
388541 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388544 - MIDI IN [DDJ-SB2 MIDI]: B0 00 13
388544 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388547 - MIDI IN [DDJ-SB2 MIDI]: B0 00 12
388547 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388551 - MIDI IN [DDJ-SB2 MIDI]: B0 00 11
388551 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388554 - MIDI IN [DDJ-SB2 MIDI]: B0 00 10
388554 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388558 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0F
388558 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388561 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0E
388561 - MIDI IN [DDJ-SB2 MIDI]: B0 20 60
388565 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0E
388565 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388568 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0D
388568 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388572 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0C
388572 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388575 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0B
388575 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388578 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0A
388578 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388581 - MIDI IN [DDJ-SB2 MIDI]: B0 00 0A
388581 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388585 - MIDI IN [DDJ-SB2 MIDI]: B0 00 09
388585 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
388588 - MIDI IN [DDJ-SB2 MIDI]: B0 00 08
388588 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388591 - MIDI IN [DDJ-SB2 MIDI]: B0 00 07
388591 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388594 - MIDI IN [DDJ-SB2 MIDI]: B0 00 06
388594 - MIDI IN [DDJ-SB2 MIDI]: B0 20 50
388598 - MIDI IN [DDJ-SB2 MIDI]: B0 00 05
388598 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388601 - MIDI IN [DDJ-SB2 MIDI]: B0 00 05
388601 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388604 - MIDI IN [DDJ-SB2 MIDI]: B0 00 04
388604 - MIDI IN [DDJ-SB2 MIDI]: B0 20 30
388607 - MIDI IN [DDJ-SB2 MIDI]: B0 00 03
388607 - MIDI IN [DDJ-SB2 MIDI]: B0 20 10
388610 - MIDI IN [DDJ-SB2 MIDI]: B0 00 02
388610 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388613 - MIDI IN [DDJ-SB2 MIDI]: B0 00 01
388613 - MIDI IN [DDJ-SB2 MIDI]: B0 20 70
388616 - MIDI IN [DDJ-SB2 MIDI]: B0 00 01
388616 - MIDI IN [DDJ-SB2 MIDI]: B0 20 20
388619 - MIDI IN [DDJ-SB2 MIDI]: B0 00 00
388619 - MIDI IN [DDJ-SB2 MIDI]: B0 20 40
388622 - MIDI IN [DDJ-SB2 MIDI]: B0 00 00
388622 - MIDI IN [DDJ-SB2 MIDI]: B0 20 00
Hi, I’m not at my computer right now but on the project file that I posted, if you change the incoming trigger to 14 bit CC 0 on MIDI channel 1 and the outgoing action as CC7 on MIDI channel 1 then it should work.
Awesome!
That got it working!
Is there a way to flip it? When i move the slider up, the volume goes down…
Also this worked only for the single slider, is there a way to do this so all of them work?
Add the following line to rules at the bottom
qq=128-qq
We would need to know the incoming message from each slider or we could use another button or knob change which MIDI message your existing slider sends.
By changing the channel from 0 (1) to 1 (2) i was able get the right slider to work as well, so I think we could be able to do something similar and address similar types of knobs in the same way
I will post the few different knobs and sliders below:
B177878 - MIDI IN [DDJ-SB2 MIDI]: B6 17 00
177878 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
177881 - MIDI IN [DDJ-SB2 MIDI]: B6 17 00
177881 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
177885 - MIDI IN [DDJ-SB2 MIDI]: B6 17 01
177885 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
177888 - MIDI IN [DDJ-SB2 MIDI]: B6 17 01
177888 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177891 - MIDI IN [DDJ-SB2 MIDI]: B6 17 02
177891 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177895 - MIDI IN [DDJ-SB2 MIDI]: B6 17 03
177895 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177898 - MIDI IN [DDJ-SB2 MIDI]: B6 17 04
177898 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
177901 - MIDI IN [DDJ-SB2 MIDI]: B6 17 05
177901 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
177904 - MIDI IN [DDJ-SB2 MIDI]: B6 17 06
177904 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
177907 - MIDI IN [DDJ-SB2 MIDI]: B6 17 07
177907 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
177910 - MIDI IN [DDJ-SB2 MIDI]: B6 17 08
177911 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
177913 - MIDI IN [DDJ-SB2 MIDI]: B6 17 09
177914 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
177916 - MIDI IN [DDJ-SB2 MIDI]: B6 17 0A
177916 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
177919 - MIDI IN [DDJ-SB2 MIDI]: B6 17 0A
177919 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177922 - MIDI IN [DDJ-SB2 MIDI]: B6 17 0C
177922 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
177925 - MIDI IN [DDJ-SB2 MIDI]: B6 17 0C
177925 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177928 - MIDI IN [DDJ-SB2 MIDI]: B6 17 0D
177928 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177931 - MIDI IN [DDJ-SB2 MIDI]: B6 17 0E
177931 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177934 - MIDI IN [DDJ-SB2 MIDI]: B6 17 0F
177934 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
177937 - MIDI IN [DDJ-SB2 MIDI]: B6 17 10
177937 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
177940 - MIDI IN [DDJ-SB2 MIDI]: B6 17 11
177940 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
177943 - MIDI IN [DDJ-SB2 MIDI]: B6 17 12
177944 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
177946 - MIDI IN [DDJ-SB2 MIDI]: B6 17 13
177946 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
177949 - MIDI IN [DDJ-SB2 MIDI]: B6 17 14
177949 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
177953 - MIDI IN [DDJ-SB2 MIDI]: B6 17 15
177953 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
177956 - MIDI IN [DDJ-SB2 MIDI]: B6 17 16
177956 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
177959 - MIDI IN [DDJ-SB2 MIDI]: B6 17 16
177959 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177962 - MIDI IN [DDJ-SB2 MIDI]: B6 17 17
177962 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
177965 - MIDI IN [DDJ-SB2 MIDI]: B6 17 18
177966 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
177968 - MIDI IN [DDJ-SB2 MIDI]: B6 17 19
177969 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
177972 - MIDI IN [DDJ-SB2 MIDI]: B6 17 19
177972 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177975 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1A
177975 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
177978 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1A
177978 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177981 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1B
177981 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
177985 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1C
177985 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
177988 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1C
177988 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
177992 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1D
177992 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
177995 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1D
177995 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
177998 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1E
177998 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178002 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1F
178002 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178005 - MIDI IN [DDJ-SB2 MIDI]: B6 17 1F
178005 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178008 - MIDI IN [DDJ-SB2 MIDI]: B6 17 20
178008 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178011 - MIDI IN [DDJ-SB2 MIDI]: B6 17 21
178011 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178014 - MIDI IN [DDJ-SB2 MIDI]: B6 17 21
178014 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178017 - MIDI IN [DDJ-SB2 MIDI]: B6 17 22
178017 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178020 - MIDI IN [DDJ-SB2 MIDI]: B6 17 23
178020 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178023 - MIDI IN [DDJ-SB2 MIDI]: B6 17 23
178023 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178026 - MIDI IN [DDJ-SB2 MIDI]: B6 17 24
178026 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178029 - MIDI IN [DDJ-SB2 MIDI]: B6 17 25
178029 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178032 - MIDI IN [DDJ-SB2 MIDI]: B6 17 26
178032 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178035 - MIDI IN [DDJ-SB2 MIDI]: B6 17 26
178035 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178039 - MIDI IN [DDJ-SB2 MIDI]: B6 17 27
178039 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178041 - MIDI IN [DDJ-SB2 MIDI]: B6 17 28
178041 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178044 - MIDI IN [DDJ-SB2 MIDI]: B6 17 29
178044 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178047 - MIDI IN [DDJ-SB2 MIDI]: B6 17 2A
178047 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178050 - MIDI IN [DDJ-SB2 MIDI]: B6 17 2A
178050 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178053 - MIDI IN [DDJ-SB2 MIDI]: B6 17 2B
178054 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178056 - MIDI IN [DDJ-SB2 MIDI]: B6 17 2C
178056 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178060 - MIDI IN [DDJ-SB2 MIDI]: B6 17 2D
178060 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178063 - MIDI IN [DDJ-SB2 MIDI]: B6 17 2E
178063 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178067 - MIDI IN [DDJ-SB2 MIDI]: B6 17 2F
178067 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178070 - MIDI IN [DDJ-SB2 MIDI]: B6 17 30
178070 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178073 - MIDI IN [DDJ-SB2 MIDI]: B6 17 30
178073 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178077 - MIDI IN [DDJ-SB2 MIDI]: B6 17 31
178077 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178080 - MIDI IN [DDJ-SB2 MIDI]: B6 17 32
178080 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178084 - MIDI IN [DDJ-SB2 MIDI]: B6 17 33
178084 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178086 - MIDI IN [DDJ-SB2 MIDI]: B6 17 34
178086 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178089 - MIDI IN [DDJ-SB2 MIDI]: B6 17 34
178089 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178092 - MIDI IN [DDJ-SB2 MIDI]: B6 17 35
178092 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178096 - MIDI IN [DDJ-SB2 MIDI]: B6 17 36
178096 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178099 - MIDI IN [DDJ-SB2 MIDI]: B6 17 36
178099 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178102 - MIDI IN [DDJ-SB2 MIDI]: B6 17 37
178102 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178106 - MIDI IN [DDJ-SB2 MIDI]: B6 17 38
178106 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178109 - MIDI IN [DDJ-SB2 MIDI]: B6 17 38
178109 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178112 - MIDI IN [DDJ-SB2 MIDI]: B6 17 39
178113 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178116 - MIDI IN [DDJ-SB2 MIDI]: B6 17 3A
178116 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178119 - MIDI IN [DDJ-SB2 MIDI]: B6 17 3B
178120 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178122 - MIDI IN [DDJ-SB2 MIDI]: B6 17 3B
178122 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178126 - MIDI IN [DDJ-SB2 MIDI]: B6 17 3C
178126 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178128 - MIDI IN [DDJ-SB2 MIDI]: B6 17 3D
178129 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178131 - MIDI IN [DDJ-SB2 MIDI]: B6 17 3E
178132 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178134 - MIDI IN [DDJ-SB2 MIDI]: B6 17 3F
178134 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178138 - MIDI IN [DDJ-SB2 MIDI]: B6 17 40
178138 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178173 - MIDI IN [DDJ-SB2 MIDI]: B6 17 40
178173 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178176 - MIDI IN [DDJ-SB2 MIDI]: B6 17 41
178176 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178179 - MIDI IN [DDJ-SB2 MIDI]: B6 17 42
178179 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178182 - MIDI IN [DDJ-SB2 MIDI]: B6 17 43
178182 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178186 - MIDI IN [DDJ-SB2 MIDI]: B6 17 44
178186 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178189 - MIDI IN [DDJ-SB2 MIDI]: B6 17 45
178189 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178192 - MIDI IN [DDJ-SB2 MIDI]: B6 17 46
178192 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178195 - MIDI IN [DDJ-SB2 MIDI]: B6 17 47
178195 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178199 - MIDI IN [DDJ-SB2 MIDI]: B6 17 48
178199 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178202 - MIDI IN [DDJ-SB2 MIDI]: B6 17 49
178202 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178205 - MIDI IN [DDJ-SB2 MIDI]: B6 17 4A
178205 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178208 - MIDI IN [DDJ-SB2 MIDI]: B6 17 4B
178208 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178211 - MIDI IN [DDJ-SB2 MIDI]: B6 17 4C
178211 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178215 - MIDI IN [DDJ-SB2 MIDI]: B6 17 4D
178215 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178218 - MIDI IN [DDJ-SB2 MIDI]: B6 17 4D
178218 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
178222 - MIDI IN [DDJ-SB2 MIDI]: B6 17 4F
178222 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178225 - MIDI IN [DDJ-SB2 MIDI]: B6 17 50
178225 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178228 - MIDI IN [DDJ-SB2 MIDI]: B6 17 51
178229 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178232 - MIDI IN [DDJ-SB2 MIDI]: B6 17 52
178232 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178235 - MIDI IN [DDJ-SB2 MIDI]: B6 17 52
178235 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178238 - MIDI IN [DDJ-SB2 MIDI]: B6 17 53
178238 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178240 - MIDI IN [DDJ-SB2 MIDI]: B6 17 54
178240 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178243 - MIDI IN [DDJ-SB2 MIDI]: B6 17 54
178243 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
178245 - MIDI IN [DDJ-SB2 MIDI]: B6 17 55
178245 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178248 - MIDI IN [DDJ-SB2 MIDI]: B6 17 56
178248 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178250 - MIDI IN [DDJ-SB2 MIDI]: B6 17 57
178250 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178253 - MIDI IN [DDJ-SB2 MIDI]: B6 17 57
178253 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178255 - MIDI IN [DDJ-SB2 MIDI]: B6 17 58
178256 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178258 - MIDI IN [DDJ-SB2 MIDI]: B6 17 59
178258 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178261 - MIDI IN [DDJ-SB2 MIDI]: B6 17 59
178261 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178263 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5A
178264 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178266 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5B
178266 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178268 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5B
178268 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178271 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5C
178271 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178273 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5C
178273 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
178276 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5D
178276 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178278 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5E
178278 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178281 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5E
178281 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
178283 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5F
178283 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178286 - MIDI IN [DDJ-SB2 MIDI]: B6 17 5F
178286 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
178288 - MIDI IN [DDJ-SB2 MIDI]: B6 17 60
178288 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178291 - MIDI IN [DDJ-SB2 MIDI]: B6 17 61
178291 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178294 - MIDI IN [DDJ-SB2 MIDI]: B6 17 61
178294 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178296 - MIDI IN [DDJ-SB2 MIDI]: B6 17 62
178297 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178299 - MIDI IN [DDJ-SB2 MIDI]: B6 17 62
178300 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178303 - MIDI IN [DDJ-SB2 MIDI]: B6 17 63
178303 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178305 - MIDI IN [DDJ-SB2 MIDI]: B6 17 64
178305 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178307 - MIDI IN [DDJ-SB2 MIDI]: B6 17 64
178307 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178310 - MIDI IN [DDJ-SB2 MIDI]: B6 17 65
178310 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178313 - MIDI IN [DDJ-SB2 MIDI]: B6 17 66
178313 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178316 - MIDI IN [DDJ-SB2 MIDI]: B6 17 66
178316 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178319 - MIDI IN [DDJ-SB2 MIDI]: B6 17 67
178319 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178322 - MIDI IN [DDJ-SB2 MIDI]: B6 17 68
178322 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178324 - MIDI IN [DDJ-SB2 MIDI]: B6 17 69
178324 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178327 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6A
178327 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178330 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6A
178330 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178333 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6B
178333 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178336 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6C
178336 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178339 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6D
178339 - MIDI IN [DDJ-SB2 MIDI]: B6 37 40
178341 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6E
178341 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178344 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6E
178344 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
178347 - MIDI IN [DDJ-SB2 MIDI]: B6 17 6F
178347 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178349 - MIDI IN [DDJ-SB2 MIDI]: B6 17 70
178349 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178352 - MIDI IN [DDJ-SB2 MIDI]: B6 17 71
178352 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178355 - MIDI IN [DDJ-SB2 MIDI]: B6 17 71
178355 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178357 - MIDI IN [DDJ-SB2 MIDI]: B6 17 72
178357 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178360 - MIDI IN [DDJ-SB2 MIDI]: B6 17 73
178360 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178362 - MIDI IN [DDJ-SB2 MIDI]: B6 17 73
178363 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178365 - MIDI IN [DDJ-SB2 MIDI]: B6 17 74
178365 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178367 - MIDI IN [DDJ-SB2 MIDI]: B6 17 74
178368 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178370 - MIDI IN [DDJ-SB2 MIDI]: B6 17 75
178370 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178372 - MIDI IN [DDJ-SB2 MIDI]: B6 17 75
178372 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178375 - MIDI IN [DDJ-SB2 MIDI]: B6 17 76
178375 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178377 - MIDI IN [DDJ-SB2 MIDI]: B6 17 77
178377 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178380 - MIDI IN [DDJ-SB2 MIDI]: B6 17 77
178380 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178382 - MIDI IN [DDJ-SB2 MIDI]: B6 17 78
178382 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178385 - MIDI IN [DDJ-SB2 MIDI]: B6 17 78
178385 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178387 - MIDI IN [DDJ-SB2 MIDI]: B6 17 79
178387 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178390 - MIDI IN [DDJ-SB2 MIDI]: B6 17 79
178390 - MIDI IN [DDJ-SB2 MIDI]: B6 37 70
178393 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7A
178393 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178396 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7B
178396 - MIDI IN [DDJ-SB2 MIDI]: B6 37 10
178398 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7B
178398 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178401 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7C
178401 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178403 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7C
178403 - MIDI IN [DDJ-SB2 MIDI]: B6 37 60
178407 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7D
178407 - MIDI IN [DDJ-SB2 MIDI]: B6 37 30
178410 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7E
178410 - MIDI IN [DDJ-SB2 MIDI]: B6 37 00
178414 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7E
178414 - MIDI IN [DDJ-SB2 MIDI]: B6 37 50
178417 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7F
178417 - MIDI IN [DDJ-SB2 MIDI]: B6 37 20
178420 - MIDI IN [DDJ-SB2 MIDI]: B6 17 7F
178420 - MIDI IN [DDJ-SB2 MIDI]: B6 37 7F
This is 14 Bit CC MIDI Channel 7 CC 23
B= CC
6 = is MIDI Channel 7 (MIDI channel 1 is 0)
17 = CC 23 (Hex 17=Decimal 23)
The third number it the MSB Value
The B6 37 xx is the LSB (always 0x20 higher than the MSB) so ignore that except for the fact knowing that it is a 14 bit CC. The rules manipulate the last numbers to come up with the desired 7 bit value.
You should be able to duplicate the existing translator the change the incoming trigger and out outgoing 7 bit CC and then MIDI learn the new knob.
