BMTP seems to suffer from this issue where if e.g. Translator 1 in Preset 1 is set to activate Preset 2 and Translator 1 (same translator) in Preset 2 is set to deactivate Preset 2, Translator 2 is deactivated as soon as it is activated.
This means I need to add delays to Translators’ outgoing action which always fixes it.
Usually I spend a couple of minutes checking, double checking my channel no. note no. Preset no. etc only to have that Duh! moment when I realise it is actually a bug in BMTP.
Hi, can you post an example? What are you using as the trigger to activate and de-activate?
