Let’s say I assigned C2 to type “Q” on keyboard. When I’m hitting C2 key I got on output two Q’s instead of one (press=Q and the release=Q). How I can configure this to make on output just one action instead of two? (press=Q and then release=nothing)
My guess is you have two input MIDI ports defined for the same MIDI keyboard. You should only choose the input once. I usually assign an alias and the use the alias only for input as shown below.
If you look at the alias setup it looks like this.
Attached is the project file.
C2-to-q.bmtp (924 Bytes)
