Is it possible to send a midi note on from one translator to another translators midi message incoming ?
If not, what would be a good way to route midi messages from an outgoing back into another translator ?
Using MT Pro
Using MT Pro
You would need something like loopMIDI or loopBE to do this, however I would not recommend it as there is a possibility of MIDI loops created. Rather, I suggest you use a global variable with an outgoing timer. Then use the incoming timer to trigger your final outgoing message.
If you can describe in more detail, what you are trying to accomplish, maybe I can help you or even suggest another way.
Or get another BOME box and feed midi into that
Thanks for your help and your offer. I will think it through myself first as I understand how the timers work
