Currently working with my Novation Lauch controller XL and rekordbox. I have small djing equipment which is integrated with rekordbox but I want to use my Novation XL along with so that I can have layout as mixer 900 specially in master fx.
So, I selected virtual port 1 and xl as input and output. Though I am receiving the signals in rekordbox but when I try to map fx pannel as - want assign particular fx (eg. Reverb) with particular pad button. I try several time but it work as select next fx, so whenever I press pad buttons it selecte new fx everytime.
How am I get there? Please help me.
Is it possible or not?
I’m not that familiar with how Rekordbox works. Usually I believe it is licenses by controller type. You might be able to merge MIDI from your Current Controller and your LCXL through the same virtual MIDI port by using the Bome MIDI Translator Pro MIDI router. Maybe, however if RekordBox allows multiple MIDI devices you can also select your LCXL as a secondary MIDI controller. Since I don’t have a license for RekordBox, I’ve no way to test this. Usually you can monitor the MIDI in Bome MIDI Translator Pro through the log Windows to see what is going on.
Maybe RekordBox doesn’t support MIDI learn unless you have authorization for a given controller type.
Unfortunately, I cannot test Rekordbox with one of their payment plans as their subscription service payment system is down. Once it comes up, you can PM me and if you want to pay for one month of service, I can download Rekordbox and test thinks out with my controllers. I have a LCXL.
