Hi, trying to encode MTP to have a MIDI controller slider sending CC to an app.
Actually it’s for a flight simulator.
On my destination app, for this particular slider, I made:
[ for ‘Down - 1 increment’
\ for ‘Up, - 1 increment’
(BTW I could encode MTP to have these up and down commands sent by pressing two keys, but now I would love to have sliders or rotative knobs on my MIDI device to send theses datas to my app.)
This is what I’ve have tried:
Incoming MIDI message:
Capture MIDI, (Ok, it sees the slider moving).
-I select the first line of the captured MIDI message
(I didn’t create any rule, nor any variable, as I need to learn this.)
Outgoing:
Key Stroke: Physical Key : \
What it does, for now:
When I move the slider, it works, but only in the Forward direction
And actually it moves very quickly…if I could have slower incrementations, it’d be awesome.
I would like to add a Translator for “Back” action on this slider, but I don’t know how to tell MTP: I’m using the same slider as for “Forward” but I want it to send another MICI CC when I’m moving the slider down?
Any help to understand the best way to do that would be more than appreciated!
Best Regards!
