Tutorial 101 Please. Utilize midi fader
Hello,
I love that I’m able to dust off my old DJ midi equipment to play Flight Simulator 24 with. Well worth the purchase of this software. But I’ve underestimated Bome Midi Translator Pro’s intricacy. I need your help.
if you can show me your Boolean Logic on…
1)How to design a fader that require repeating to press a key exponentially at its height (127)
2] an encoder that can incrementally +/_5 ( ‘F’ key strokes ) up down
3) Button when help down translate keystrokes faster.
I’m excited for this software! :heart_eyes:
Youtube was unable to help
thank you
Before we go too far, there are many gaming applications that block keystrokes generated from the actual keystrokes, so make sure that this works with the trial version of Bome MIDI Translator Pro before proceeding.
The attached project file should help.
Translators 0.0 and 0.1 handle pushing a MIDI controller and sending a CC (fader) value up and down respectively. We use the global variable ga for the desired output value. Rules in translator 0.0 increment the value of ga by a pre defined amount (local variable pp). Translator 0.1 handles decrementing the amount.
Here are the rules of translator 0.0.
//determine increment about
pp=7
ga=pp+ga
// don't let value go over 127
if ga>127 then ga=127
For your second requirement we initiate sending 5 “F’s” with translator 0.2 which starts a repeating timer. We set the number if times to repeat and how often in the outgoing section.
The timer simply sends the keystrokes when triggered. The keystrokes will be sent to whatever application is focused.
For the third requirement, I’m not sure what you want as when Bome MIDI Translator Pro translates keystrokes, the incoming keystroke is not suppressed. For this I would suggest using AutoHotKey if on Windows and perhaps Keyboard Maestro if on Mac.
We could certainly use a timer to send keystrokes out at whatever rate we want but the application may not recognize them if the rate is too fast.
For the translators 0.0 through 0.2, you may want to modify your incoming trigger for your controller. Also you may need to modify your aliases.
Mine are set up as shown below:
