We just published a new tutorial allowing the focused application to switch to a given preset. Here is the description.
In this Tutorial, we show a way to enable different presets in Bome MIDI Translator Pro, depending on which application is currently active on your computer.
As an example, we are using a single controller to control the mute and unmute functions of two different applications using keystrokes. The keystroke sent is dependent on which application currently has focus. You need Bome MIDI Translator Pro 1.9.0 or later for this project to work.
The project file used in this tutorial is attached.
Application-Preset-Switcher.bmtp (2.8 KB)
