Uninstall Bome Midi Translator Pro Trial Version
I would like to know how to unistall correctly the Trial Version before installing the Complete Version (on macos 10.14.6 Mojave)
Do I move the app from “Applications” folder to the Trash directly?
Are there other files from User folder or Library that I should remove before installing Complete version?
Thx
Yes, just delete the executable if you are on Mac.
See this post about where files are kept.
