Hello,
I would like to be able to quantize some CC messages to the next musical grid, for example 1/4 note.
I understand that I should delay the input CC of the value need to get to the 1/4 note, but I miss several things. I’m not sure how to get the bpm value (as I would need it to get a delay in ms), and I’m not sure how to get the right grid division.
Hope I’m clear enough !
Thanks for any incoming help
Hi and welcome to the Bome Community.
The best way to handle this with MT Pro is to.
- Upon MIDI start command, start counting timing clock messages, up to 12. Quarter notes occur on every 12th timing clock message.
- Capture the last CC command into global variables with a different translator but do not send it
- On each 12th timing clock message, send out the last captured CC message (if there was one present). Then clear the CC message (to indicated there is no longer one present). I usually use a negative value to show that a message is not present.
The only caveat here is that if you get more than 1 of the same CC message in between the 12th clock message, only the last message will be captured (which is probably what you want anyway).
